Got an issue with my instrument cluster, cuts out on pressing accelerator pedal and car stutters.
changed cluster still faulty, changed integration still fault present
any ideas anyone.
Integration relay sorry left that one out
I had this once. It was a simple resistance build up on the -ive and +ive terminals of the Battery. In the end, the Battery was dead enough so it got replaced anyway.
Thanks, I shall try a new Battery
Why not first try cleaning the Battery terminals and the earth strap to body work   before renewing an expensive Battery ?
A simple voltmeter test on the Battery and alternator would also show up any problem there, plenty of Ytubes showing how to test them with a cheap meter.
