Hi guys another fault code has come up. After clearing the and sensor fault that is
C1208 Steering position output signal.
Does anybody know what this fault is and how do you fix it please.
Thank you Paul
This specific code states "C1208 - ABS Rear Isolation Valve Circuit Short To Battery". Is the MIL engine light on?
First check to see the ABS fuse is not blow and replace it if so.
Then check to see if the ABS cables are connected per wheel, reconnect and drive for 15 mins to allow the ECU to re-learn it is good again.
However this error may not be an ABS problem because this error can appear for a lot of unrelated problems also. If you have the radio code, try disconnecting the Battery for 10 mins and then reconnecting it to see if the problem disappears.
