Warning Tyre Pressure Light -How to reset
diane
Hi, I have a toyota auris 1.3 2015- and I have a problem with the tyre pressure warning light. My tyres are ok, so how can I reset this light. Where is this function on my car please?
Mine is on the right off the glovebox when it is open. To reset, turn on the ignition and then hold the button, when the warning light stops flashing, it is reset.
  • 6 months later...
It's annoying in the Auris Hybrid that the tyre pressure warning indicator doesn't indicate which tyre is low, so I have to go round all four tyres to find out.  But then again, at least it means that I check and adjust each tyre, which is no bad thing.
