I`m thinking of hard wiring my dd pia M6 plus to my mk2 new shaped Toyota Aygo  but i`m not sure which fuses i have ie mini ,midi,or larger of the variety so that i get the right piggy back add wire  for the job ...can anyone enlighten me of which i possess please thank you .
Moved to the Aygo club
Could you not have a look in the fusebox, remove a fuse and check? You will be removing a fuse anyway to intall the piggyback.
I would suspect that they are low profile mini fuses. A mini fuse will fit too if they are (same blade sizes but longer). Make sure the piggyback is the correct orientation when fitted.
thank you for your help ...Low Profile mini fuses it is then ......weather permitted will be doing it on saturday next 🙂
Thanks again for your help 😁
Did it work, Ian? I'm going to have to get one after all the hassle of my Insurance claim..
Yes all up & running  front dash cam and rear stand alone  cam ,including home made footwell mood lighting bought blue LEDs £4.95
