Has anyone put this sort of lighting into their cars ? if so what system did you use & how you neatly fitted them to your car ? has i`m toying with the idea to fit them to my latest Aygo mk 2   ! 🙂
Moved to the Aygo club.
have a live supply to them and use the door switch to activate them,
any light delay on the interior light should still work with the footwell lights
as the interior light will still be earthed for those extra few seconds.
I fitted these to our Pug 107, so sort of related, I bought some LED light strips with sticky backing and attached them under dash. I traced interior light wiring, on 107 removing A pillar trim on drivers side gave good access and tapped into that. Did this many years ago, so cannot remember exactly, but think I only used live feed from interior light and then earthed to interior light door courtesy switch, so they come on/off with that.
