Water infiltration
stefano70
I have infiltration of water in my Rav 4 III 2006. Did you find some solution?
Which area of the car is water present??
Moved to the Rav4 club.
Passenger side. Under the carpet. Thanks for you help!
This was a very common problem at one time and often occurred after a windscreen was replaced. An inadequate seal on the scuttle cowl cover allowed water to flow into the cabin air intake, then draining via the ventilation system on to the front carpet. This seal was often damaged when a windscreen was changed. There was a TSB on the subject which involved fitting an improved seal.
https://www.rav4world.com/tsb/2006/BO021-06.pdf
Thank you very much! I hope that this intervention solve the problem.
