2010 Avensis 2.0 D4d aircon bypass
19mick87
Hi I dont know if this has been brought up before, but basically my aircon compressor is making noise at idle and when driving it gets quite loud. No gas in system as the condensor has a leak, so Im guessing bearings are bad from running dry.
Is it possible to remove the aircon unit and bypass that pulley by using a shorter drive belt?
If so does anybody know what size belt is required. The engine code is 1AF
Cheers
Cheers
Sorry its 1adftv engine
Part number 90916-W2034 from your local Toyota dealer fits the 2.0 1AD without AC
Cheers is there a diagram of the pulleys with the smaller belt on so I know how to bypass it?
Hope this helps -
 AVENSIS |  V BELT
The A/C compressor itself will not be running if there is no gas in the system because the low pressure switch will prevent this by keeping the A/C clutch deactivated. The clutch on the compressor will spin and it is possible this is noisy in its own right... but make sure as it may be something else such as a noisy tensioner or alternator bearing.
Alternator is a year old so should be fine. Narrowed it down to water pump or  ac compressor. Have a leak in ac condenser over a year so no gas in the system had it tested in the summer so Im asssuming its the clutch in the compressor thats making the noise.
Got the shorter belt just havent had the chance to do it yet. Looks like the car has to be jacked up to get to the tensioner aswell.
When the belt is off ill check all pulleys and run the engine to see if noise is gone.
Sounds like a plan... good luck and let us know how it all works out.
On many recent aircon systems there is no clutch on the compressor. Instead the compressor shaft spins all the time the engine is running with the aircon load being controlled by a swash plate inside the compressor itself. On both our 2009 Auris and 2012 Avensis the aircon compressors don't have a clutch.
Having said that, this type of compressor is designed to be run for some time with no refrigerant in the system without sustaining any damage.
You can usually identify this later type of setup by the fact that turning the aircon on or off doesn't produce the characteristic 'click' of the clutch from under the bonnet which older aircon systems used to have.
Are you certain ? I couldn't find reference to any type of non-clutch set up for automotive use.
A clutch under control of the pressure switches is one of the main safeguards in a system. You wouldn't hear the clutch cycle on and off as in a fixed displacement compressor as it would be engaged all the time the AC was on (unless overridden by external factors or the user switching AC off).
Just after swapping the belts around a pig of a job even with the car on the ramp. Very little space to work with but new belt fits perfectly.
The noise is gone and there was a lot of play on the aircon pulley which was also leaking a lot of the dye used when I got a leak test done on the system in the summer.
Thanks for the asvice and correct belt size its after saving me a lot of money not having to get a new ac compressor.
Pleased to hear you have found a fix and its quiet now.
Yes, they have become quite common in the past decade or so. VW for example have been using clutchless variable displacement AC compressors since the early 2000s, my 2007 Skoda Octavia had one. From what I can see our Auris and Avensis have this type of compressor too.
Interesting, thanks 🙂
An Audi I once had used a variable displacement compressor but it still had a clutch as a means of turning the system on/off and preventing operation in to cold conditions.
Your video seems to imply that compressor failure on the type of compressor shown would be handled by means of a friction plate designed to slip and fail should the need arise. Very interesting.
The early clutchless compressors fitted to VWs unfortunately had quite a reputation for failing, and if they seized internally the pulley would freewheel to avoid the belt burning or being thrown off the pulleys. I used to frequent the Skoda forum when I had my Octavia and aircon failure on those (and the equivalent model Golf and Audi A3) was a commonly mentioned issue. Luckily I never had that particular problem on my Skoda.
I had the evaporator fail on the A4 (leak) but at 6 yrs old I didn't get it fixed (£500+ for parts plus anything up to 15 to 20 hours labour). It was one of many many issues with Audi.
  • 2 months later...
My T27 2,0 D4D had same problem... Terrible rattling noise when idling. When I pushed the pedal a little bit, no noise.
First I thought that the timing chain has gone bad, but then I listened carefully with rubber hose and noticed that the noise is coming from a/c compressor pulley.
When rotating the pulley by hand it came out that there were too much clearance between pulley and that metal plate which is bolted to compressor shaft.
Inside the pulley are some rubber dampers and they must have gone bad...
I searched this forum for help and found this topic. I watched  the video above and had an idea!
I extruded some elastic sealant inside the pulley through the metal plate holes (12) and after 24 hrs drying no clearance, no noise.
This is temporarily repair, but interesting to see how long it lasts...
Hope this will help others with pulley problems...
  • 1 year later...
quick question i have a 2014 touota avensis  a 2.0 d4d with 1ADFTV  engine code will this ac pump by pass work on mine also Part number 90916-W2034 from your local Toyota dealer fits the 2.0 1AD without AC. will it fit my engine exactualy with no loos in the belt
  • 2 months later...
hi there by chance would this work on the newer 2014 2.0d4d 1adftv engine code avensis .with this belt you are talking about (toyota genuine  90916-W2034 2.0 1AD without AC)
i have chatted with a guy before who had a 2014 avensis 2.0d4d and he said to me if the belt goes to buy a genuine toyota belt as the other brands are just a wee bit bigger and cause the engine to squeak .i was wondering is there any other place where can get a genuine toyota  belt as  90916-W2034  without AC as i put this into eBay or a search engine and i cant find any genuine toyota belts only other brands .any ideas there buddy or do i have to go to a toyota deller .the problem is the dealer would want my reg and well he might not give me that belt i need .as i googled that part number and no genuine toyota belt with that number came up
  • 11 months later...
I managed to bypass my Toyota corolla 2007 2.0 D4D today. The performance has greatly improved. Smooth and swift acceleration, with smooth changing of gears. I think the aircon compressor bearing was binding increasing the load on the engine. It was also producing strange noises. I have had engine cut off before of which I suspected that the compressor might be seizing.... Thank you for the advice. I believe there will be an improvement in fuel efficiency.
I have been thinking of doing this for a while now.
Does anyone know the alternative belt to bypass the compressor on a T25 1cd-ftv?
Cheers.
Marc
AC broken and too expensive to fix? That's the most common reason.
That’s no reason to bypass the compressor.
  • Haha 1
  • Confused 1
tbh if mine goes that i will be bypassing my ac thats for sure
This topic is now closed to further replies.
