Suspension?
Darren
My T-Sport has just been lowered 30-35mm on a Koni suspension kit. I've got 16inch Toora platinum 8.
It does sits ok, but could probably do with being at least 25mm lower.
Any ideas (other suspension manufacturers etc)
Both shocks and springs, complete kit. It does sit alot better than standard, but isn't decked. The handling is really good, I've got it adjusted about half-way.
hmmmm
i fitted TTE Springs and Koni Shocks and it dropped by 60mm
i originally fitted the springs to lower but the caused sever arch scrub so i added the konis to try and stop it. but the pulled it down a furthar 30mm cos they are a lot shorter than the OE shocks??
I'm not wanting to buy a different set of springs unless I know it's going to sit lower. I was thinking about e-mailing Koni direct and try to get a set of custom springs manaufactured. Avo done this for my last car, free of charge. Koni could be different though.
