Number plate lamp body - part number required
cptfrederickson
Evening all. Can anyone find the part number for the body for the rear number plate lamp?
The missus broke one of the clips on the body a while ago so the lens does not clip on anymore. I can find the part number for everything but the main body itself, so hoping someone more knowledgeable can help me out.
I've attached a diagram with the part I need circled in red. Its one of the two clips that are shown that have broken off, so the lens no longer attaches. I would like to avoid water ingress over winter, so will have to resort to gluing it on if I can't get the part...
I would reccomend trying the scrap yard.
Sent from my VTR-L09 using Tapatalk
Thanks guys. No joy so far with breakers or on the site linked.
I've emailed a couple of places so hopefully something will come of it.
i suspect that as that is the main part it may not normally come on it's own.
e.g. www.ebay.co.uk/itm/Genuine-Toyota-Lamp-Assembly-License-Plate-8127002131-/221837773605
Just use some silicone, it's hard enough that it will seal it good + water resistant, but can come apart easily if needed to replace the bulb.
Alternative would be hot glue.
There's no need to waste money on a new part.
Managed to get the part number from Toyota eventually. They sell it as a full lamp assembly but not too pricey so will grab one after payday.
Which model do you drive and engine. Just wanted to kniw what oil you use. I got an oil change due soon. Im unsure what to use.
Check your handbook, that will have the details for your car's engine.
