1990 carina fuel pump
I have A 1990 carina 5 door exec,2000cc,where is the fuel pump located?It"s not in the tank!
Hello.... Engine number or reg no. ? If its efi then h/p fuel pump likely in tank.. If carb then on can, on head.. ??
2sav
Definatly NOT in the tank!
..... are you here for help or an argument, m8 ..... 🤐
Of course, you don't actually say, if its a 2C-L Diesel......
Its driven off the cambelt 😉.... And will be under the covers [likely]
^^ *just for some clues*
2sav
1998cc
petrol,engine number 3s1275644,vin...jt1lst17100048390,
not looking to argue,but I"ve had the sender out!
Fair enough 👍
You have NOTHING REMOTELY like this in the tank... You don't have a large securing ring.... You don't have a high pressure/'depress the clip' fuel line connector ??
If you aren't running the car/have the tank open/loose bits kicking about.... Some pictures of your tank 'sender'??
Does you engine look anything like this... ??
2sav
