Toyota corolla e11 facelift lowering springs
Hi, what should I do now, I putted Eibach pro kit lowering springs to my corolla and the front springs are good and stif but those rear springs are wery loose and dropped my car wery much... Now my wheels are rubbing against my car.
How can I lift my corollas rear springs a bit up? Also should it be like that or have they sent me wrong springs or have there maybe happened some manufacture failure with them?
Some forum members might come in who  have fitted similar, but would think your first contact, with those pictures, should be with Eibach to check all the correct parts were sent ?
Have you got larger than the standard tyres on your wheel rims? This can have the same effect if you fit new softer springs.
  • 3 months later...
Hia
Front is About 5cm higher than back of the car with original sice wheels.. So it looks like the corolla leans back. I dont know if front should be lower or back higher or both. Any tips how I could get it look nice.
