1AD injector removal
Duggerz
Good morning all,
I decided to do the injector seals on my T25 today, and I removed the cam cover successfully, but the first injector I tried to remove looks like it's welded itself in and despite even using a small crowbar won't come out. If anyone has ideas or has experience removing these I'd appreciate the knowledge. Otherwise I'm thinking that it might be a case of see it back up and leave it until it dies, which given his right the injectors seen to be, might be a while. Pretty sure I've removed everything I need to, I do have the procedure from Toyota tech. Thanks for any help.5edfa2c08dd95a76f0fbc5655a4a2b1e.jpg
