DIY service, checks and lubrication required?
Ebob01
I am thinking of servicing my 2008 1.8 vvti Avensis myself this year, has 110k on the clock.
Apart from oil change, air filter, spark plugs what other checks and lubrication are required?
I will adjust the handbrake, the coolant isn't that old so will leave that, might change the gearbox oil and cabin filter.
Are all the suspension components etc. checked during the MOT? Is there anything like that not covered which needs checking?
What about lubrication apart from door hinges and bonnet catch is there anything that which needs doing, do I need to remove rubber boots/gaiter and grease any ball joints CV joint etc? Steering rack need greasing?
