Wet Carpet
kalif350
I have discovered that the carpet in front of the drivers seat is wet. It has been raining a lot lately here in Denmark. What and where should I check to find the leak?
Can I buy a Yaris repair manual somewhere on the net?
check the air con pipe (if you have it) that is located at the top of the footwell, mine came loose a few weeks back and my passanger footwell was soaked
the same side as your driver side i presume, dont know if all the pipings the same but just have a look for a small rubber tube dangling around.
Cheers
Niz
My passenger carpet has been wet! but the mat wasnt? Strange That explains it I think, I'll check mine after!
Cheers!
get the sound insulation out to dry too :thumbsup:
this pipe is the biggest fault ive found so far with the car, a stupid place to put it any passanger who stretches thier feet out could dislodge it :angry:
Niz
make sure the driver goes to the toilet before each jurney
maybe the drivers side window was open when it was raining, check the door seals
is that the little black thing that pokes through the hole in the floor?
yeah what is it, it get in the way of my wiring
yes mate thats the one, the AC drain pipe :thumbsup:
Well I dunno.... I've never had that problem :P hehe
*hugs Yaz
