2005 D4D rough idle
bluerav4
I bought my daughter a 1.4 D4D Yaris. The car drives and sounds perfect apart from in the morning while the cold temp lights on. It doesn’t misfire but just the ticover sounds a bit rough a bit like a lorry. As you start driving it’s fine. Once the blue light turns off it stops and sounds absolutely fine.
Ours is similar. A treatment with Redex fuel treatment (for diesels) helps a little.
That’s great thank you for your reply. That’s a load off my mind as I was thinking it maybe something drastic 👍🏼
