12 V battery check on display
Jon A.
Hey
does anyone know the sequence to display 12 V Battery health on display for 2014 auris ts hybrid?
There are some prius videos on YT where they press a button while blinking headlights three times etc but none of these seem to work for this model.
with the ignition turned on
press and hold the setup button on the headunit and turn the headlights
on then off 3 times
this has always worked on our 2013 hybrid Auris
we have the touch & go headunit
Thank you it worked, any tips where i could find 12 v Battery diagnostic?
Wouldn’t want to click to mistakes.
dont think this is in the manual.
use the next page button until you see the menu you need
to exit just turn off the ignition
not much on the other page as well but i'll try to play around with it (hopefully without problems).
