Hie im having an issue with my speedometer light and dashboard are not lighting on same as to day time light and tailighting i have chacked my fuse box in the bonnet all fuses are correct but failing to locate the error please help
Presumably the instrument lighting is dimmer when the tail lights are on?
They is no headlights indicator light on my dashboard it
I am a bit confused what your saying
Do you mean your instrument lighting is too dim ? which can be adjusted with the mileage knob
If it is the same as my Corolla
Dab once = trip reading 1, dab again = trip meter 2, dab again is instrument lighting brightness, looks something like    - - ===
With lights on press and hold, it will go up and down, until you happy with brightness with lights on
Never heard of an Allex ?
Let me try to take pictures
No electrical power light on speedometer needles same as gear lever
Sorry still not sure exactly what you mean
Has this happened recently and did it work before  ?
I suspect you need to increase the brightness to light needles, if its the same as a Corolla, follow my instructions above
