Need help d4d 06 idler pulley
Swissy
Hi I've searched for hours now but can't fine the part I need ,I'm after the long bolt that adjusts the tension pulley on my avensis d4d 2.0  06 estate it's snapped off looks like ages ago the belt needs adjusting but can't as only half a bolt please help Dan
Edited by Swissy
Not sure what you mean.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F312039163200
The hex moulding on the right of the image is designed to accept a socket (on a breaker bar) which then is the leverage to rotate the entire assembly around the bolt going through the hole at the top of the image. This releases the tension on the auxiliary belt to allow replacement.
There is no 'adjustment' as such. If the damper has failed the complete unit should be swapped over. Failing that, just the damper will be a dealer only part I suspect so expect to pay dearly.
Which engine? as the 2006 2.0D4d is a crossover year from the early 1CD 2.0 Timing belt engine to the later 2.0 D4d 1AD Timing chain engine and can you post a picture of the part?
This is the part I was after but nowhere in the UK sell it.
If it's just the bolt see:
