Installing USB/Aux-In (blue tooth or wired) to factory radio
Has anyone added a USB/Aux-in to their factory radio? If so, any recommendations on reliable adapter kits? There are sooooo many on the market to choose from. I drive a 2007 Corolla D4D with the CD/DVD navigation system (part # B9003) and I'm open to either the wired or bluetooth options. Any tips or suggestions for pulling this off are also welcome. Thanks in advance.
Not an update I have done, but if you Search this forum section you will find its been covered several times, though you may consider fitting a new head unit instead , again covered many times in the forum.
Also look in the  look in the Audio section of the  forum -
https://www.toyotaownersclub.com/forums/forum/19-audiovideoelectronics/
