15" Wheels coming soon
I have got some 15" alloys for the Aygo, and was wondering what is more likely to be a better fit, and size.
195/50 or 195/45 x 15
My car is on KYB Excel Gas Shockers and Apex springs, so is sat a bit lower than standard
195/45 is the better size. Using 50’s will start putting your speedo out, in the worst direction as well. 70mph indicated will be 72.4, 30mph indicated will be 31. Not horrendous but something you need to be aware of. Anyway, the 45’s will look a lot better....
Using a 38mm offset will stand the best chance of you not rubbing on anything.
Thanks mate, yeah that's what i was thinking with the speedo.
Ill have to check what offset they are, i cant remember.
They are the same as the wheels i used for wets on my Swift Sport Track car, but 4 stud.
Suzuki Ignis Sport 15" Enkei's
Just to add, ive since found that a 175/50 x 15 is a great fit and virtually the same rolling radius.
Here is a 107 with some fitted on these Mini One alloys, which i think do look pretty good.
