avensis T25 2.2 110kw
Reinis
Hi, Avensis T25 2006 2.2 110kw, till the car warm up u can  set inside temperature normaly and blows warm air, when  engine temperature is on work temperature, the warm air coms only when i set up 26 degrees or more,  i had allready changed inside temperature sensor nothing happening
