2005 Toyota Avensis Hatchback Water getting into left-hand lens
Stephen Andrews
Hi   i have a 2005  Toyota  Avensis  Hatchback  water getting into  the left-hand  lens  as it kept blowing  bulbs  I decided to remove  the hole lens  and found water  down in the bottom  panel   so I picked up  another  lens  and fitted  if back only to notice   a  few days after I fitted  it     that  I could see water back in the  lens again 😒🙄 so  I don't  know   what to do next  maybe  you guys  can help!?
Moved to the Avensis club.
was the replacement new or s/h? Probably the gasket that has gone - common issue.
