MK2 rear light update
Richiesheep
Hi All,
Need some help, I for some reason thought it would be so easy. how wrong I'm. I brought the MK2 rear lights for my 64 plate auris hybrid estate.
Now having very quick look, it looks like the connectors on the inner rear lights have changed. Is there anyway of making the mk2 inner work with my 64 plate mk1??
please help if anyone can.
1thank you very much.
ask the seller of the rear lights if they have the rear light wiring plug
you could then solder it into the loom and either have both plugs
or cut off the original connector then solder in the new one
