General Advice Auris Windscreen Washer Pump
stu_cole
Good Evening Forum
I'm after a bit of advice
Over the last couple of months i've noticed that the water has been getting further down the screen and now is struggling to hit the bottom from the jets
Q1. Is it a known thing for the pump to become more and more asmatic
The back is OK but I didn't realise until today that it is a dual pump system
I have ordered a new pump but had a couple more questions
Q2. Is there anything else to look for......there are no water leaks......and as i'm guessing the jets aren't blocked as both are weak
Q3. Do I access the pumps from the drivers wheel arch or from the front of the car
Any help would be great
Have a good evening "forumneers"
Mystery solved: I lifted the bonnet and activated the washer. A big plume of water shot across the car park........it appears there IS a hole in the pipe. The pipe has been rubbing against the felt cover on the underside of the bonnet
I think i'll try a puncture repair outfit first as a temporary fix and then get some washer hose for a more permanent repair
GGGGRrrrrrr if only I'd tried this first I wouldn't have bought a new pump........ and i've got to order some washer pipe.......... and run it from the reservoir to the two nozzles
Can you not return it (if you mail-ordered it you can under Distance Selling Act within 14 days of receipt)?
This topic reminded me that i need to actually investigate why is that, when i fill up water in my Windscreen washer bottle.
Water leaks out.
