Avensis Tourer 2012 Door Mirror
Dazsw
Hi guys,
Someone has driven into the Avensis and wrecked the drivers door mirror.
Got a replacement aftermarket item but the LED does not function.
After receiving another with the same result I did a bit of digging and on their website "Trupart" only specify a mirror up until 12/2011 part number MM7738, our car made in 03/2012.
This is what I was sent and after that the next mirror starts at year 2015, so a weird 3 year gap with no mirror specified.
Does anyone know of any other aftermarket type suppliers?  Failing that it's breaker time.
Cheers.
I have checked two sites - http://www.japan-parts.eu/toyota/eu/2014/avensis/adt270r-awfeyw/2_273560_009_530W/electrical/8106_side-turn-signal-lamp-outer-mirror-lamp#81730 http://www.toyodiy.com/parts/p_E_200812_TOYOTA_AVENSIS_ZRT271R-AWFEPW_8701.html
and ToyoDIY, and both give the same info and part no. 81730-05070 for drivers side LED from 0811-1505 (November 2008 to May 2015).
Your car 'should' be covered from the first year of the Avensis build, so I assume the Trupart components either are not compatible or faulty.
