oil quantity
roger_37
im gona do gearbox,diff and transfer oil in the motor, what i need to know, how much oil for each  part...ie gearbox diff and trans how much oil for each,i know which oil but not know quantity.thanks
Hey,
One method of finding this out would be to look at your manual, there might be precise amounts stated. It's definitely the case for engine oil but for other oils it might not be there, in which case you'll need a service manual (different from your standard user manual, it outlines a lot of troubleshooting, repair steps, etc.). Might ask for it here or find it yourself on the Internet.
Another method would be to go to a few different oil company websites, Motul, Mobil, etc, and enter your vehicle details - exact year, engine modification and so on - and check out what quantities they're stating.
While this is a faster method, I would double-check with the manual but if 3 different oil manufacturer websites say the same thing, it just might be true.
Are you changing the lubs on both motors Martin as you have two different ones on your profile ? Just wondering if that would help anyone who can help  to do so with correct data
Del
Del
only have the rav4 for now, going to buy something new for the better half.
Very tactful reply there matie. May be wrong on this but do not the gearbox and transfer box share the oil and do you not fill them till the oil creeps out the filler/level hole ?
What engine and gearbox ?
whant i need to know ..how many liters would i need for that
6 minutes ago, Devon Aygo said:
What engine and six speed gearbox ?
2.2 engine and  six speed gearbox
Edited by roger_37
Assuming you have a 4wd version
Engine 5.9lt 0w30 Acea C2 (prefered) or 5w30 Acea C2 & 38nm on plug
Manual gearbox 2.1lt API GL-4 SAE 75w & 39nm on plug
Transfer box .45lt Hypoid gear Oil SX API GL-5 85w90 & 39nm on plug
Rear differential .55lt Hypoid gear Oil SX API GL-5 85w90 & 39nm on plug
thanks devon aygo just what i needed.
