Parking brake problem
Taxi100
Strange problem , my parking brake warning comes on after I've done a hill start . after I switch off the engine and restart the warning light goes off . any ideas , its a 2008 t27 model
Hi John, welcome to TOC 🙂
Please confirm what model as afaik all T27s are 2009>.
Sorry its a 2.0 d4d ,must be 2009 . the problem only seems to occur when I have passengers and luggage in the back
1 easy way to solve the confusion - manual handbrake or epb?
Brake fluid level might be a bit low which would put on the light
Thanks taxi501 that would make sense as like I said it only happens when stopped on an incline .I'll look into that now
Well I topped the brake fluid up ,wasn't much needed and it seems to have done the trick , thank you so much
Bear in mind that when brake pads wear the system uses more brake fluid to push/hold the pistons out further.  ie there's a fair chance your brakes are getting thin.
