rear passenger window
eygo
came home from work today and told by other half the r/n/s window sounded really rough
i stripped the door down thinking i would see some teeth missing / worn on the regulator
or loose mounting bolts for the regulator , unfortunately i didnt see either the motor
was also tight, i decided to put a little grease on the regulator teeth and also in the
window guide rail where the regulator wheel moves this has now stopped the noise
and made opening the window nice and smooth again, i never thought it would of been
a lubrication issue although i'm not moaning it cost nothing to fix.
