axle hub nut replacement
sauter
toyota avensis 2006 diesel 2.0l d4d 126bhp
hi, I just had to replace my alternator, sadly it needed the drive shaft to be removed in order to slide out the alternator from behind the engine........
anyway,
I need a axel hub nut replacement because the old nut was crimped ( i didn't realise and it took quite an effort to remove!!)
so i wont put back on the old crimped hub nut, but i can't find a number part, or a place to order it from.. any help??
The hub nut part number is 90177-22001.
http://www.japan-parts.eu/toyota/eu/2006/avensis/adt250r-awfeyw/3_273550_138_352W/powertrain-chassis/4303_front-axle-hub#43501H
AVENSIS |  FRONT AXLE HUB
You can use the old hub nut until you get the replacement. Don't worry about the crimp. It is only a backup to the nut being correctly torqued. Also I am surprised you have not visited a Toyota dealership to at least get a price. They may not be as expensive as you think. On eBay the average price is £6.20p
Edited by Konrad C
More info
