Problems with Toyota Yaris 05
Harv01
Hi There,
I have a Toyota Yaris 2005 model and recently I’ve been having some problems and wondering if anyone could help.
My steering whilst I’m driving occasionally becomes very heavy requiring a lot of strength to steer the car which is not normal. I don’t know if this could be a problem associated with the ABS as this light seems to light up when this occurs.
On one other occasion today I turned my engine off and when I went to turn it back on several minutes later my engine wouldn’t start and immediately cut out however a few minutes later would start normally with no problem. Could this be associated with the cold weather.
Thank You!!
Harvey
I would check the Battery. The steering wheel motor maybe not getting enough voltage....
As above, check the basics, Battery, earth connections & power steering fluid. ABS light could be a sensor although should throw up a code if you know anyone with an OB2 code reader.
