Oil dipstick
Haitham Mohamed
i pull the oil dipstick to check engine oil level while i put it in the hole i flip it to the another way and i put it in the hole i would like to know if there any problem putting the dipstick at any side
the difference between each side that; there's side the high and low points is popup on the surface while the another side the points flat on surface
My car: Toyota Avensis 2008 T25 (gasoline) Saloon
Motor:3ZZ-FE
IMG_0024.thumb.jpg.67e05ff00e9e85b49e5e8e59715d749f.jpg.f347ea87b90cbf3576a3d651c323b8da.jpgIMG_0023.thumb.jpg.9b3ac8b8191ddad90fd746d94ea51e05.jpg.dcbde8cea75dfde7a09fa1a4774a2ff4.jpgIMG_0025.thumb.jpg.2a99240452c5a26fddb0a1c1b972caaf.jpg.d0f2658989d9b51ddebb70aad1f1f0d1.jpgIMG_0026.thumb.jpg.e27a8f2728d6d2e03e9a68b4fc2b10c6.jpg.ff89660bdafe00c5497042523579a6dc.jpg
Moved to the Avensis club.
I would say no problem, a raised pimple or a dent, they just markers and as long as oil does not exceed the high mark nor be below the lower mark you are ok- though I would make sure the oil level is always nearer the top mark then the lower mark.
