Oil dipstick
Haitham Mohamed
i pull the oil dipstick to check engine oil level while i put it in the hole again i didn't put it in same way i pull it up mean that i flip it to the other side so i would like to know if there any problem putting the dipstick at any side
the difference between each side that; there's side the high and low points is popup on the surface while the another side the points flat on surface
My car: Toyota Avensis 2008 T25 (gasoline) Saloon
Motor:3ZZ-FE
Hi Haitham, welcome to TOC 🙂
You won't have any problem - it's just a straight dipstick
