T25 mirror indicator
Eightball
Hi
I have been informed by my local garage that the wing mirror indicators on my avensis are LED and you have to replace the whole unit (£95 from Toyota.)  Does anyone know if I can get one cheaper or if there's an after market part?  When I search it come up with the Prius wing mirror indicator.... are the parts common?
Many thanks
Ian
8 minutes ago, Eightball said:
Hi
Many thanks
Ian
Hi Ian,
I don't know about aftermarket parts, but if this happened to me I'd be tempted to source LEDs from fleabay and solder them on the existing board, assuming I could get that plastic cover off. Assuming that is that there are just dead LEDs and the whole board hasn't gone pop.
Regards, Ian
Part numbers:
81730-05050 RH
81740-05030 LH
£83.04 ea incl vat
Try a good breakers yard there's got to be a few about and if you cant get the right coloured one you can always spray it.also try eBay thers usually a good supply of parts on there.but on my Avensis the door mirror indicators are bulbs .Google Toyota avensis door mirror indicator bulb replacement  it's an easy fix.
  • 3 years later...
On 2/5/2019 at 7:29 PM, Devon Aygo said:
Part numbers:
81730-05050 RH
81740-05030 LH
£83.04 ea incl vat
where can these be obtained? Mine only work when the weather is hot!
either high resistance connection of dodgy led's....
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
