Semi-Automatic Gear Box.
MGR1
Can anyone tell me what the normal maintenance is for the Semi-Automatic Gear Box from my Auris 2010.
I cant find anything.
I think its using the brake fluid for shifting and this must be changed every 2 jears.
Can anyone help me how to fix this?
Thanks.
Moved to the Auris club.
It is a recommendation that brake fluid is changed every two years but it will not be in your gearbox.
If it's a MMT then it is an automated manual gearbox. i.e. a conventional 'box with electricly operated clutch and gear changes, all computer controlled.
Whether it has the same oil as a non automated version, I wouldn't know but it is doubtful that brake fluid is in there.
I tought its a electric /hydraulic unit that operated the clutch and gear changes.
And the hydraulic part use the brake fluid to move.
But I don't know 100% sure
In the gearbox is the same oil as in the manual gearbox.
hi marcel
it is the same oil as a manual gearbox as the gearbox in your mmt is a manual gearbox
its just the gear change that is automated.
" I tought its a electric /hydraulic unit that operated the clutch and gear changes."
No hydraulics as far as I know. Just glorified wiper motors.
You right I saw it on the internet no oil inside I think I saw a old model.The gear box is not a smooth one
but the thing I don t like  about  the gearbox it shift back to the first if you still drive 20-25km/h
this is also in the M or in the E.
With a normal manual gearbox you only shift back to first gear if you standing still .
Is there any way to make this happen or with Techstream? or anything else?
I want to adjust it .shift from first to second (quick 10-15 km/h) and only shift back to first if you standing still.
hope any body can help me.
Thanks and have a nice weekend.
