2009 rear brake caliper carrier bolts
The mallard
Hi does anyone know the spec for the bolts that hold the rear brake caliper bracket to the hub, not the caliper bolts. Mine are somewhat rounded and was hoping to get new ones from the local bolt supplier rather than toyota. Or worst case anyone know the part number?
Late 2009 rav 4 diesel
mallard
There will most probably raised letters/numbers on the bolt head that your supplier will know which specs of fastener you require
Del
Part number 90105-12314 £2.00 form your local dealer
That’s great, many thanks , I had thought it would be extortionate from Toyota but clearly not !
