Part Number and Name Please
David Marietta
Hi All,
Firstly, newbie to the site - owner of a 1994 GX for close to two years, an absolute gem. I recently reversed into a hidden unmovable object which split this part causing the rear wheel to stick out at a severe angle and needs replacing Can anyone please provide me with this part number and proper name (sub-assembly, wishbone?) and any indication as to where I may be able to source a brand-new part besides from car breakers. It would be for the RH (driver's side) rear one, unlike the photo, in case of confusion. Marked with the red "X".  Many thanks.
Moved to the Rav4 club.
Toyota call it an "Arm sub assy, rear suspension RH" part numbers are:
48711-42904 with ABS
48711-42905 without ABS
they aren't cheap £697 + vat you will also need a rear wheel bearing as the hub is pressed in through the wishbone and looking at the condition in the pictures I suspect you will need a whole lot more nuts, bolts, brake pipes etc
