No 'N' after Aygo MMT clutch change.
ClutchStinker
I used techstream to clamp before removal. Changed clutch, no issues. Put gearbox back on, rebuilt. The clutch literaly had nothing left on it and had completely failed. Before I took it apart, the 'N' would flash. I observed when I first turned the car back on that it was in '5'. I used to techstream to learn new parts. I couldn't complete the learning as ignition couldn't be started due to it not being in neutral (stick was in neutral position though) Upon turning car back on, the section that displays what gear you are in is blank.  Any help?
(06 plate 1l aygo)
  • 10 months later...
Your unlikely to get a response as the op has been on here since Feb 2019
the reset procedure can be found in this pdf
INF12215_GB.pdf
my god what a procedure that is
how on earth did toyota / 3rd party come up with that solution to manually setup the MMT
unbelievable
Its just as bad as key programming, Techstream does make it a lot easier tho
Eeeeek.
Glad I avoided (just) buying a 65k km MMT car!
