Avensis interior light fuse... Help!!
Paul_Dawe
Hi guys, just changed a bulb that was out in the interior dome light and now I have no interior lights... Can someone tell me which and where the fuse for this is as I have checked all the fuses behind the glovebox and they all appear to be fine.
Thanks in advance
Sent from my SM-G965F using Tapatalk
I Googled your query and got this -
Balikbayan's post shows another fuse box that may help.
Do you have the owners manual? The contains all the info you require.
Thanks... I have got the owners manual but it doesn't tell me squat. The fuse box that should be behind the cover by the steering wheel is actually behind the glovebox.
