Instrument Lights
brimar
:o I have a new Yaris 1.3 T3 Spirit automatic. When the headlights are put on, the digital instument readout goes dim. Whilst I can understand this from a glare point of view, it is no use when the lights have to be put on in bad weather for example and I can only just about see the speedo. There is no meantion of this dimming in the handbook. Is there a way of controlling the brightness of the digital readout?
Cheers me dears
Brian :arrgg-matey:
Yup! Just press the button in front of the display that toggles mph/kph. It also changes the display (bright/dim).
Just make sure you practise when stopped. Don't want you travelling around with a km per hour readout (unless that's what you want!).
Personally, I prefer the brighter display to be on even at night in town. That dimmer display is better on unlit country roads though.
I had the same problem until a month or so ago...I thought it was me going mad when the display was going dim..I have the bright display on whenever I put the lights on now
