Yaris Hybrid Side / Running-Lamp Replacement
OldNick
Can anyone explain how to remove the dual filament lamp fitting on a Yaris Hybrid to replace the bulb? It looks the same as the headlamp (HIR2) bulb fitting but it does not twist off in the same way. Many thanks.
Nick Hi,  Twist out the bulb holder, and at the bottom where the wires go in is a small lock. Press lock and pull out bulb, it's a wedge type (21/5 W). Refitting is reverse. Don't hold new bulb in your fingers or you'll be replacing it again soon.
Thanks everyone. I think I was not twisting it hard enough for fear of breaking something. I'll try it again tomorrow.
Nick
