Best Double Din Android Head Unit
Siddu_j143
I have a 2009 Toyota Avensis 2.0L D4D diesel car:driving: I have got a standard audio device OEM Part Code: 86120-05150 or unit name: W53828
I am looking to replace the double din with the latest Android head unit and welcome suggestions. Requirements to support the steering wheel controls, maps, USB and Bluetooth for phone connectivity.
Anyone who might have done this or have some experience, please share. Thanks in advance. Cheers!🙂
Edited by Siddu_j143
year missing
You will need to visit sites like Connects2 http://www.connects2.co.uk/ and Autoleads - https://autoleads.co.uk/ . They supply the fitting parts you require. As for the stereo, you need to do a Google search. Some Android systems don't use standard connectors, and I advise not to cut any wires in the loom! I rather have adapter cables because if the Android unit has a problem, the wiring and plugs will be there to put the original unit back. Also makes for a better plug and play, and safer too.
I have installed an OEM Toyota Android system in my car last year and will send you information if you still require it.
