Thanks from RAV4 owner
mobile armchair 2
Don't know where to post this as I found advice in several of the RAV4 sections of the forum, but having had the RAV4 dashboard light up like a Christmas tree, and having looked at all the excellent posts on here, was able to alert my mechanic to the fact that just because the ABS and brake system and VSC warning lights were on, this did not mean a complete breakdown of the entire ABS system, and that they might check the brake pedal actuator no matter what the code fault reading was. And the brake pedal actuator was indeed the culprit ... it makes such a difference even if you don't fix these things yourself to be able to walk into the repairers with a hint of where they might start looking. Thank you all contributors. 😋
Btw, having paid for the diagnostic and the minimum 1-hour labour (a reasonable total of £64), I had fitted the £28 Toyota genuine article rather than the £7.99 option. Didn't seem worth paying for the cheap option if I had to fork out another £64 sooner rather than later ....
How gratifying it must be for the learned members on here who answer the many questions posted on these forums to see a post like this. Nice one Keith
