Broken tailgate lock
Duncsribs
Struggling to find Toyota Avensis 2003 tailgate push button key lock.  Can only see bottom section on eBay etc. but need the actual push-button key lock.  Can anyone suggest place/advise.  Thanks
Moved to the Avensis club.
You aren't going to find an off the shelf part as the lock is only supplied as a matched part, which requires your chassis number to order and the part will be supplied with the key barrel matched to your original locks.
You will need to contact your local Toyota dealer to order
