T25 anti roll bar bushings
Regressor
Hi, anyone here that has installed new bushings on the front anti roll bar?
I looked in the workshop manual but could not find a guide on how to do this.
I did the rear ones and they were easy, but they were also easy to access..
The bushes are just a split rubber bush square at the bottomand  with a rounded top to fit the U shaped bracket. Only two bolts each side. You just need to work out if the roll bar will lift when you loosen the bush and if  so you mayt need to jack up the side you are doing so the roll bar hangs down onto its seating. I did a Yaris recently and it took me about 1 hour for both sides.
Hmm, ok so i tried this project last weekend but was not able to get to the bolts on the left side bushing. (From under the car) The brakelines go right past and it was very little space to get a ratchet with the cup in there and get leverage.
Not anyone else replaced their bushings in the front? I will look for some special wrench extenders or whatnot on eBay, or if anyone has any pointers shout out!
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
