weird chugging
ProfGlenn
Hi - I have a 1.8 Auris Hybrid.  Tonight as I pulled away from the traffic lights there was one big chugg.  Then fine.  Happened three times in a row at three sets of lights.  The car was not cold.  Then a faint smell of fuel.  Then all seemed fine.  Any ideas?  Thanks, Glenn
How much miles on the car? On the PriusChat there is many reports that >150k miles EGR system starts to block out and needs to be cleaned or replaced. EGR system parts: cooler, valve, pipe ftom valveto intage manifold, then small egr passages on intage manifold.
Rough starting, lowspeed are reported for example when EGR is blocked.
EGR cleaning videos along with others on this thread: https://priuschat.com/threads/prius-gen-3-major-maintenance-egr-manifold-spark-plugs-oil-catch-can.203069/
Thanks.  Only done. 63000.
Is it the same as your previous topic?
See
Hi - that was a different chugging.  That was more like the car was trying to throw up.  This time it's a gentle chugg pulling away from stationary.
