Starter Motor
jimtaxi
Having trouble with starter motor disengagement now and then but probably will be permanent eventually.How do you remove starter its a 2012 T27 2.0 D4D.
First thing I would do was to disconnect the Battery, then remove the two or three cables on the starter,then it is a matter of removing the bolts holding the starter. Is there any chance that these are not fully tight ? Not sure if it is two or three on your motor. Make sure than the shaft is clean and dry which would rule out a faulty rear crankshaft oilseal. An auto electrician or savvy mechanic would have the means to bench test the starter and also if there is anything wrong with the bendix (the sliding gear)
