Steering wheel issues since software update?
danowat
Car has been faultless since I brought it, until the recent software recall update.
Steering wheel now wobbles, similar to how it would with unbalanced wheels, however, it 'kicks' too at low speed (you can feel it if you crawl as slow as you possibly can), which you'd only get if the wheel or tyre is damaged, no damage on either wheel or tyre.
Coincidence?, something mechanical failing at the same time as the update, or can the software affect the electric PAS?
If the problems started immediately after the  recall update, then I would go straight back to the garage to get it sorted.
However, if the problems started a few days later, I would first start checking wheel balance weights, tyre pressures and condition, and steering linkages.
