Under Bonnet Hose Cips
mickandjanet
Hi have noticed rust and corrosion on a couple of hose clips in the engine bay, are these items under warranty parts, also some rust on edge of disc brakes but this is treated as normal.
Brake discs, as with most manufacturers, only carry a limited warranty. Would not have thought the hose clips would be covered unless they are starting to fail.
Could sea air be affecting the clips as they are often made using mild steel which draws moisture from the air. You could treat it with wire wool to clean them and then apply a coat of lacquer on them from swmbo's make up bag (but don't say I said that)
This is the same with any car the discs are steel obviously can't be coated so will rust. What would you like from warranty?
