Hi all,
I have done countless googling and I keep getting different results.
I just want to know what bulb fitment is for the foglights on a 2005 FL T sport please?
I'v read HB4 or H11.
Also i've read this job is abit of a pain? the sticky instructions link is broken.
If it's the same setup as my standard 2006, then you have to unclip the side panel of the plastic under engine protector. The trickiest part is working out where all the clips are! Once you have gained access the rest is easy, just a twist fit bulb with a connector.
I came across those two bulb types mentioned, and the way to be sure is to take one out. As with so much in life, the anticipation is worse than the actual job.
H11
