Hello,
My last Aygo had mud guards, my new one doesn’t.. it’s really noticeable how dirty the side of the car gets, but the back is the worst without them covered in mess
I have found the OEM mudguards on the Toyota eBay store, has anyone fitted them? It looks simple enough just a couple of screws. I’m not sure if holes are already on the car I will need to check. I hope I don’t have to drill the body.
eBay item numbers
223063297258 (rear)
223063211462 (front)
I purchased some for my previous auris and they came supplied with screws/bolts that replace the plastic clips already in place. No drilling required and the genuine Toyota ones also come with instructions. I didn't notice any real difference with them on personally and the front ones left a permanent line on the paint where the guards touch the wings! This was only noticeable when I took them off.
Accessory fitting guides here
Fronts here
Rears here
On 3/27/2019 at 7:35 PM, AYGOSTU said:
Hello,
I have found the OEM mudguards on the Toyota ebay store, has anyone fitted them? It looks simple enough just a couple of screws. I’m not sure if holes are already on the car I will need to check. I hope I don’t have to drill the body.
Ebay item numbers
223063297258 (rear)
How did you get on with these ? Be interested to know, do they help keep rear of the car a bit cleaner ?
